Hi all, first post on here, hopefully with a successful outcome!
I have an Accenta 8 Mini alarm (old I know) and it's been pretty reliable but the other night the alarm triggered when it wasn't set. It was at 3.30am so was a rather rude awakening! the tamper light was lit but none of the PIRs were lit up. My first thought was it's probably the battery failing although I was of the belief that this would only happen in the event of a power cut? Anyway, for the sake of a few quid I bought a new battery and have fitted it but this hasn't solved the problem, the alarm triggers usually only after a few minutes after fitting the battery and clearing the tamper fault.
Can someone point me in the right direction? I have checked all thev PIRs and the panic button in the bedroom and they all seem to be working fine and there are no obvious wiring faults inside the panel?
Thanks in advance
Thanks in advance
