- Nov 28, 2009
- 14,729
- 903
That was just an example picked at random.Pro Dave
Thanks - I think i'm finally starting to understand.
The Drayton LP112 you linked me to says it has common timings for heating and hot water.
Is it ok to go for the "top of the range" which allows for separate timings for heating and hot water? See here :
http://www.screwfix.com/p/drayton-lp722-mk4-programmer/26078?cm_sp=Search-_-SearchRec-_-Area1&_requestid=946340
Many thanks
Yes you can have one with separate times, but bearing in my the limitation that you can't have heating without hot water as your plumbing is set up (and remember to configure it for "gravity") But you can have the hot water coming on earlier than the heating if you so wish.
