ParkySparky
Just reading through some old posts and the am2 was mentioned.
Wiring the 2 way lighting circuit.
Am I right in thinking this is done in t&e now?
We had to use metal conduit, kicking back to walk out of trunking, then it had 2x90 bends in it! Only just enough conduit to do it and only 3 couplers, one to bush in light, one for trunking and one to split tube between the two 90 bends if you couldn't manage it in one piece!
It was then wired in singles, it was a 2 way and intermediate circuit with landlords over ride, also incorporating a em fitting with neon indicators on the switches!
Is the motor start/stop/inch still in the test?
MI cable to 3 phase and neutral socket?
Surley not changed much has it?
