got a shark 100 quad bike to fix. starter motor turns it over, there is a spark and there is fuel, but it just wont start. taken carb apart, tried easy start and still nothing. any ideas?
2 stroke. separate tank for the oilis 2 stroke or 4 stroke?
fresh petrol, drained all the old fuel just incase it was thatmay be stating the obvious here,but is it fresh petrol?,
they cant really go off timing unless the flywheel has sheared the key on the crank.
if its flooding straight away the plug will be really wet,
take the plug out and try turning it over with your thumb over the plug hole, you will be able to feel the compression(it wont be much in that little engine),
that way you will feel if its getting fuel too,
if its been sitting a while could be crank seals dozed and oil getting into big end, or sucking air in from the other side,
remember 2strokes compress below the piston as well as above.
2 Stroke Engine Animation And Diagrams
