In the days of wiring combi,s,I remember there was always a link to remove to wire in the clock and/or room stat using voltage free connections.I recently wired a greenstar Ri regular on a y plan & the switched live from the valve simply went to terminal LR on the boiler,no sign of any removable links,so is this common on this type of boiler,or does it depend on manufacturer?
Ps,A builder had tried to wire boiler before myself & may have tampered with connections. Regards,HZ
