Does it Lurch?Does this not pretty much deem this tangent as pointless at this point.
Why?
Also, what thread size, that's the screw size.Let's say brass - 4.0mm.
Well, we're looking for a torque to apply to socket terminal screws, your detailed line of questioning pretty much shows that this is not something that you can calculate on the job. Unless the manufacturer stipulates what torque the terminal should be tightened to then you can't be expected to apply a specified torque to it.Does it Lurch?
Why?
Come on. You know where I am going here. If the manufacturer guidance on torque settings must be adhered to for MCBs then surely the same must be true for accessories which must state that they should also be installed to meet the standards that the materials allow.Grade of brass?
What is it going into?
It must be adhered to, IF, it is specified.Come on. You know where I am going here. If the manufacturer guidance on torque settings must be adhered to for MCBs then surely the same must be true for accessories which must state that they should also be installed to meet the standards that the materials allow.
I am just trying to highlight how sometimes people just do things without questioning why. I have never and will never use a torque driver. Also if these manufacturers instructions were so good why has amendment 3 seem to have thrown that out by bringing in NC CUs?
I thought that's what he was trying to say as well.Exactly what I am trying to get through to Essex, however, as usual, he won't listen!
But that is my point. Is the reg only worth following when the torque setting is given to you on a plate? Who really checks what the torque requirements are for a socket? No one does. But it it's the same thing as a MCB.I'd say sidewinder is more authouritve than me on this,
I generally work more with engines,
But, there will be a standard torque for a 4mm brass screw,
But fkd if I can be bothered looking it up.
It also needs to take into account the material it is threaded into as well,
Beaten to it,, :|
Please let us not get rude. It is a conversation.Exactly what I am trying to get through to Essex, however, as usual, he won't listen!
How short? Wanna bet?It must be adhered to, IF, it is specified.
However, manufacturers of accessories do not require it, thus it does not need to be done.
You will start using a torque driver, like it or not, as you will be mandated to do so, by your clients in a very short space of time.
I was waiting for someone to say that. Surprised it took so long. Haha.So,, playing devils advocate here.....
We HAVE to torque down any screw that the manufacturers deem necessary because of a reg in a book that is non-statutory that we don't "have" to follow?
Needless to say I do have a torque screwdriver and I've even started using it
BTW,,, have you seen the "Torqued up" stickers that the NICEIC are selling??
What I cannot understand is how members can choose that the reg means only MCBs. Not accessories.
So how can someone say that MCBs/RCBOs require it but accessories do not?
Following manufacturers instructions.
This all started with someone quoting reg 526.1 which states nothing about manufacturers requirements. That is when I questioned the reasoning. Since then other regs have been brought in but IMO 526.1 does not require a torque driver to meet it.Essex.... if you look at the regs,, they state that we should be installing IAW the manufacturers instructions.
Now if the manufacturers state that we need to tighten certain screws to a certain torque then that is what we should do....
If the manufacturers instructions don't say anything about tightening up the screws to a specified torque then there is no instruction to follow
?????What I cannot understand is how members can choose that the reg means only MCBs. Not accessories.So how can someone say that MCBs/RCBOs require it but accessories do not?
It doesn't require one to meet it but proving that it is met would be easier if you used a calibrated torque driver. That is all.This all started with someone quoting reg 526.1 which states nothing about manufacturers requirements. That is when I questioned the reasoning. Since then other regs have been brought in but IMO 526.1 does not require a torque driver to meet it.
Same question you asked an hour ago, answer still same.?????
What? your repeated question about why we should torque MCBs etc and not accessory screws??So can anyone answer posr#72?
