I live in the mountains of Mallorca and the isolation means water by truck which is then pumped around the house and garden by one of two electric pumps. I have a challenge. If a hose is left turned on at the tap but off at the hose head then the heat slowly allows the hose to become elastic and the pump keeps getting a signal for water and eventually the hose fails or the head flies off!! OK I should always turn off at the tap. This means the pump now pumps my precious water down the hill. I have five toilets and they also occasionally stick on "flush" (gritty water etc) This also means my valuable and expensive water is pumped to the septic tank and eventually the tank is empty. Is there a run limit switch that I can fit to the pumps so that after an hour or two they time out and are switched off? This would have to be automatic as sometimes I have to be away for a day or two. Any ideas please?
