Went to look at a job today where a fan needed to be replaced in the ensuite shower and a fan in the bathroom. The ensuite shower was actually a walk in shower straight off the bedroom, the screen being made up of those glass blocks. In the area that is zone 2 is a double socket!! . I know you cant apply the regs retrospectively but you can point out the potential dangers. Back to the fan for the en-suite. There was one there originally and had a twin+cpc feeding it although this had a 3 pole fan isolating switch on the wall which also isolated the seperate light too. A bit of rewiring needed there with some 3 core+cpc as the client wants the fan to run on for a bit. I then asked to see the C/U to see if there was any RCD protection but there was none. I wasn't happy about fitting a new fan in this situation. The C/U in question was a Wylex 10 way with BS 3871 breakers in. I've suggested RCD protection should be considered and the client is interested in getting the C/U replaced. I'm concerned about the double socket next to the shower enclosure. Not 100% sure what to suggest really.. Any suggestions???
