MARK MCCANN
- Joined
- Nov 23, 2020
- Messages
- 19
- Reaction score
- 6
Morning
Been looking to have my main fusebox swapped (all rcbo type circuits) will need more capacity (especially in the kitchen in the future)
The meter is outside on porch wall and existing fusebox is other side of porch inside, near the ceiling.
Spark is saying that owing to dot and dab plasterboard on porch wall, he has to add in an switch fuse arrangement and a fuse in order to protect the cable as he is unable to get beyond 50mm depth for the cable.
Also because the cable is longer than 3m.
He is also suggesting larger cables (25mm) saying the existing (tails/cables) are 16mm and it would be worth upgrading.
He has said then the electricity board will need to upgrade their fuse to 80 (60) is in now.
The switch that he is talking about putting in also has an RCD as part of it and this projects the tails. The fuse that comes with this switch has an option of 3 sizes and he says he will fit 63amp. Someone else I know said it should be lower than the electricity boards which is 60 now. Although I hope to have it upped to 80. I have read some of the guidelines about upgrading the fuse size from the electricy board and seemingly most can be upgraded (max is 100 apparently) The spark also said there is two more fuse sizes supplied with the proposed new switch box (80 and 100) Is what he is saying ok? And also if the 80 upgrade fuse goes ahead, will the 63 have to be changed to 80? I'm thinking on the extra capacity in the kitchen further down the line.
All pretty much complex stuff and the spark in question appears component and says all will be tested when done and test info on paperwork will be supplied.
Would appreciate any thoughts/info
Tia
Mark
Tia
Mark
