- Dec 25, 2011
- 5,460
- 70
The fault is BACK on the home phone line, same as we had earlier this year. No phone or broadband. Reported and got the stock "the fault is on or near your property" etc. 3 days to fix etc. Really needed it last night for work and had to go to the neighbours.
Just to make sure I thought I'd double check "our" side: Pole in the street with a 2 core, figure of 8, blue drop wire to the corner of the house. Grey BT box with a few cobwebs etc and a brass terminal strip. The cable from this runs along under the eaves down the wall and in through the side of the window to the BT master socket. This cable looks like this:
![bt_001.JPG bt_001.JPG](https://cdn.imagearchive.com/electricianforum/data/attachments/6/6445-3352933f82557b026782fb61f444d995.jpg)
The cable is several metres long tacked here and there, covered in masonary paint etc. I isolated it both ends and whacked the meter on. Have continuity on both cores (same resistance). Only oddity was the IR - looking at around 250Mohm - would have expected infinity. Guessing a bit of a breakdown somewhere as this black 2-core looks very old.
Whatever, I bypassed this cable with a couple of single 1.5s and still the same - no phone/b'band. I even connected a master direct to the grey box again no dice.
The teller I guess is zero volts apparent on the line!
Main question though, where can I get some more of this black cable or is there a modern equivalent? Tbh I'm tempted just to run a length of 2.5 T&E in some mini trunking with the CPC snipped out and just heatshrink the last foot and 2 cores in black!
Thanks.
Thanks.
