Assuming are we?? Now you know thats not allowed on here.So you only check the accuracy once per year? That worries me. Could be wrong for 364 days.
I can assure you Steptoe that I have been testing long enough to know what range I need to select when testing.its not an NIC thing,the law simply states you should have accurate test equipment and a method of showing it is accurate.
try looking after your kit in future.
its usually a good idea to select the correct range before blaming the manufacturer.
The Analogy of comparing calibration to an MOT test if that was correct would leave a lot to be desired, as we all know you could put a car into half a dozen different mot stations and get different results. a pass in one can be failed in another and a fail in one can pass in another.I think the MOT analogy is a good one.Once a year I have to put my car through an MOT, but on a weekly basis I check my tyre pressures and oil level etc.
Some people dont bother to do this and rely on the MOT.
So oil, tyres etc get checked once a year.
Is the car safe, maybe, or did you get a puncture the day after the MOT ?
Any check is only valid at the point it was made, the checksheet is the equivalent to checking your tyre pressure once a week. It may not be the same as a full MOT but at least your checking to see nothing has gone seriously wrong.
May I ask how often you or your assessor check that the meter totally complies with the requirements of the regulations.at my last assessment the assessor (we are NICEIC AC) actually stated that yearly cal was NOT a requirement,especially as we have 3 meters that are checked on a rig monthly and any discrepancies woul;d immediately be obvious in either the checkbox or meter,
it would be one mighty coincidence for all 3 meters and checkbox to deviate by exactly the same amount.
Yes we do calibrations as do other people on this forum , we have not hidden that fact and need to make a living just like everyone else here needs to make a living.The Analogy of comparing calibration to an MOT test if that was correct would leave a lot to be desired, as we all know you could put a car into half a dozen different mot stations and get different results. a pass in one can be failed in another and a fail in one can pass in another.The other major difference is MOT is a Legal requirement, Calibration IS NOT
Its just Firms with their own Agenda trying to make it appear so.
quite right,May I ask how often you or your assessor check that the meter totally complies with the requirements of the regulations.and how often does a calibration centre send their meters for calibration?
it must be every other week I suppose due to the number of other people depend on you having calibrated meters to test with,
Do you do all of the checks that are outlined in my detailed posts above, it is not about base accuracy, that is probably the least of your worries.
Yes we do calibrations as do other people on this forum , we have not hidden that fact and need to make a living just like everyone else here needs to make a living.The above is rather like me saying "I don't care about qualified electricians coming to do a professional and certified installation in my house, to hell with the regs I'll do it myself"
You are quite correct that calibration is not a legal requirement but it is a requirement to comply to regulations, it quite clearly states in the regs what the minimum performance that is expected from your testers so as such it implies that you need to prove this on an ongoing basis. Self checking does not do this, it provides spot checks of base accuracy.
what regs would that be?
It has also long been a requirement that instruments are traceable to national standards, this cannot be achieved in any industry if calibration is only performed outside the manufacturer recommended limits. For the type of testers you use and for checkboxes this is 12 months.
Has anyone dared to ask their NICEIC inspector why they say otherwise on their website and why their checkboxes state quite clearly that calibration is required every 12 months? Seems like some contradictions going on to me.
but they dont make the rules, do they?
Not good - not good at all.
8.7.1 - Basic requirementsWhat regs would those be
So the general guidance to electricians working to BS7671 would IMHO be:-Instruments should be regularly re calibrated using standards traceable to national standards, or have their accuracy cross-checked using know references such as comparing readings to those obtained by other instruments, or by the use of a proprietary instrument 'check box' having clearly defined characteristics.{next paragraph and over to page 82.}
In all cases the type and frequency of recalibration or checking required should be as specified by the instrument manufacture taking into account ambient environmental and usage factors as appropriate. For example, if an instrument is left stored in a constant temperature in a dry environment for long periods and is used infrequently, the user may be able to extend the recalibration interval. However if an instrument is roughly handled and is regularly stored in vehicles and hence is subject to fluctuations in temperature and humidity caused by changes in time of day/night and time of year then more frequent confirmation of accuracy would be appropriate.
You seem to have taken this personally, this was not a personal statement about you or anybody else on this forum it was a general comment about firms, although maybe It could have been worded better, Vested interest would probably have been more appropriate than hidden agenda.Yes we do calibrations as do other people on this forum , we have not hidden that fact and need to make a living just like everyone else here needs to make a living.Not good - not good at all.
Not by giving an incorrect impression to customers, that would be like us giving customer the impression that a pre 17th edition consumer unit is unsafe.Yes we do calibrations as do other people on this forum , we have not hidden that fact and need to make a living just like everyone else here needs to make a living.Not good - not good at all.
Not the same at all as its not a legal requirement to be a qualified electrician, you can Legally do Notifiable work yourself as long as you go through Building control or a part P scam ProviderThe above is rather like me saying "I don't care about qualified electricians coming to do a professional and certified installation in my house, to hell with the regs I'll do it myself"Not good - not good at all.
Also not the same. as certification is a legal requirement of Building controlThe above is rather like me saying "I don't care about qualified electricians coming to do a professional and certified installation in my house, to hell with the regs I'll do it myself"Not good - not good at all.
It is not requirement Legal or otherwise to comply with the Regs in fact it is actually permissible to deviated from the regs, Its down to our professional judgment. most professional electricians have deviated from the regs at some time or otherYou are quite correct that calibration is not a legal requirement but it is a requirement to comply to regulations, it quite clearly states in the regs what the minimum performance that is expected from your testers so as such it implies that you need to prove this on an ongoing basis. Self checking does not do this, it provides spot checks of base accuracy.Not good - not good at all.
Is it not very coincidental that they have changed to this since they have been associated with a calibration house, vested interest/hidden agenda springs to mind.Has anyone dared to ask their NICEIC inspector why they say otherwise on their website and why their checkboxes state quite clearly that calibration is required every 12 months? Seems like some contradictions going on to me. Not good - not good at all.
They are cross checked every morning and night with primary standards and are calibrated every 6 months to UKAS standards at a cost probably 10 times that of buying a brand new checkbox.pleas remember GN3 is exactly that, it is NOT a statutory document AFAIAA.and how often do you send your meters away to be calibrated by an independent source?
after all, think if you even only do 10 meters, multiplied by 364 days = 3640 installations to be tested wrong, at one periodic or new installation a day, sometimes I will test 3 or more shower circuits in one day, so I guess there could be thousands of people with a dangerous shower because I didnt have a checkbox and instead relied on some calibration company with a dodgy meter to give me a printout saying my meter was OK cos their uncalibrated meter said so.
