Hi All,
I do in fact have a class one HGV licence, so yes, I can reverse trailers!!!
I will give you all a few "trade secrets" !!!!!!!!
1, Before you start, have a walk around your vehicle and have a look what is there, get a sort of mental picture of it. This will make it much easier, it is also vital for safeties sake...
2, Plan your attack!!! Try to look at what is there, and plan your vehicles movements in your minds eye to get where you want to be.
3, Forget looking out the back window.... The first time you drive a truck with a sleeper cab you will not even have a window, and even in the car/caravan world, all you are going to see is the front of your load...Not very helpful..
4, All this crap about "the steering goes the wrong way" forget all that, you will merely confuse yourself...
5, So, what is the "trade secret" then??? Right, first off; ALL reversing is done purely using the mirrors.
First off, adjust the mirrors so that when the vehicle and trailer are in a dead straight line, when you look in the mirrors, you can see STRAIGHT down each side of the vehicle. You want the view in each mirror to be the same ON BOTH SIDES
Now, the hardest bit is to go straight backwards, but going straight backwards is the way to do it.. otherwise you will just tie yourself up in knots..
So, REMEMBER THIS To go straight, which ever mirror the trailer appears in, TURN THE STEERING THAT WAY and you will go straight!!!!
So to reverse miles in a straight line, just keep looking in the mirrors all the time. Say the trailer appears in the left mirror, turn the steering wheel left!!! The trailer will disappear from the left mirror, and appear in the right one. Turn the steering right!! the trailer will disappear again, and pop up in the left mirror!! so all you have to do, is to keep on looking, and whichever mirror the trailer STARTS to appear in, turn the steering that way, and, you will just, using very fine movements of the steering, go perfectly straight!!!!!
So, say you want to reverse into a drive/loading bay. [we will assume here, as it is easier to describe, that the road is quite wide]
Lets do it on the wrong side, just to make it more fun!!
So, we want to get into a drive on the left hand side of the road.. Drive down the road in the normal way, then using your judgement, turn the vehicle sharply so that you will be as close to 90 degrees across the road as you can, with the rear of the trailer as close to in line with the entrance as you can.
Next, LOOK IN THE MIRRORS
We see [looking in the mirror] that the trailer is too far to the left. So what do we do??? We do not want the trailer in the left mirror, so we turn the steering that way, just the same as to go straight!! It will now pop up in the right mirror, more where we want it!!!! Now, once we have judged it has moved the right way enough, we want it back out of the right mirror, SO STEER THAT WAY!!!! It will now appear in the left one!!
If we now pull the whole lot straight forwards, hopefully, the trailer will be in line with the entrance. All we have to do now, is to go straight back, and everytime the trailer appears just the slightest in a mirror TURN THE STEERING THAT WAY... We will sail straight back in a straight line into our entrance!!!!
Same principle to go around curves; when you get baffled, and forget which way to turn, [and you will!] just remember, whichever mirror you DO NOT want the trailer in, steer that way!!!!
Try to keep things straight though, so a curve would be best done in a slight threepenny bit style [apologies to anyone under 50!!]
Try it and see, it is all a LOT easier to do than to write about!!!! Once you have the basics, just practice. BUT ALWAYS REMEMBER THE THING ABOUT THE MIRRORS, and you will not go far wrong "which ever mirror it appears in, steer that way!!"
john..
