can you help on these
searley
Sep 12, 2008
320
can`t get formulas for these ?
1.when a semi conductor diode is connected across an ac supply having a peak value of 5v,the peak inverse voltage across the diode is ?
2.a circuit has a resistance of 20ohms and an inductive reactance of 15ohms when connected to an ac supply.the impedance of the circuit is ?
thanks for the help chaps.
answer 1, 7.07 2, 25.0ohms
I think question one is along the lines of the PIV should be 1.4 times greater than the supply voltage rms..............that is a dim memory but I do remember something along that line & cant be arsed to dig out & dust off the old notes from college.
Question 2
Z=square root of R + XL
Z = impeadance
R = resistance
XL = inductive reactance
Z= sqrt of (20x20) + (15x15)
Z= sqrt of (400 + 225)
Z= sqrt of 625
Z= 25
Something like that.............I hope
