- Joined
- Dec 25, 2011
- Messages
- 5,470
- Reaction score
- 80
My own place.
The time has come to invest in some CCTV (and possibly some break beam alarms) to cover the front of the property. The frontage is approx 150' wide. Something I've been meaning to do but recently found that within 1/2 mile there is going to be a new traveller's site so it's batten down the hatches time. Got to the point where I couldn't even have the garage door open or the existing local ones would pull up at the bottom of the drive and have a peer in bold as brass etc. There's also been burglaries all around; heating oil, trailer & gate thefts etc. I had a pressure washer and coiled extension nicked off the drive when I popped back into the house to get the garage key. They even fly tip up against the "No Fly Tipping" signs. Police are useless. The local stations have all been closed and combined into one 15 miles away. The couple opposite in their 90's were broken into and it took 2 days for the CID to turn up.
A high gate stops them peering in but if they jump over then they are in fact screened from the road and it probably aids them.
I don't really want to go wireless and would prefer hard wired. The obvious route is a 50mm polypipe conduit that runs (<10m) from inside the garage under the block paved drive to the sliding gate motor - +18" deep btw, backfilled & taped. Looking at it now it would have been easy (then) to run a second duct, hindsight etc! This currently contains two 1.5mm 3-core SWA (and a draw wire). One supplying 230vac to the gate and the other (again mains) for the gate pillar lights.
My query then is will I be asking for trouble if I run CCTV cabling within this duct? Does SWA have any screening effect or is it "leaky" in terms of EMF? Was also considering running some cabling through the same duct so I could fit a keypad OUTSIDE the gates on the pillar and possibly the break beam wiring too. Or should I be thinking screened cable for these "other" services?
Worst case I bite the bullet, excavate and put another duct in.
Many thanks. Next question will be "what" CCTV kit! :lol:
