Looking at installing some downlights and also fix a few pendantsAre you trying to avoid the joists,,,i.e when installing downlights from beneath a ceiling , or are you trying to fix a standard type of light from below ?
mollys are a better fixing, but then you need to drill hole, fit, pull tight, remove bolt, then attach whatever is it. riva's are so much easier to use and only need a driver / cordlessPlasterboard fixings are great
???All pedants should now be capable of carrying up to 5kg so plasterboard fixings will not do.
Sorry, should have said that all supports for pendants should be capable of up to 5Kg.
Never heard them called that before either. Andy, wheres that name come from?I've got few boxes of them just didn't know they were called that. Cheers mate
