Ceiling light help.
Andy58
Jan 22, 2021
Hi great forum, thanks for the ad.
I want to fit a new ceiling light, coming out the roof it has 2 black wires ,joined, 2 red wires joined,  and a single black. The connector block on the new light fitting has brown and blue.
Any help greatly appreciated thanks.
At a guess...
The two joined blacks would connect to the Blue.  (Neutral)
The single black would connect to the Brown.  (Switched live)
And the two reds joined need to be put in a separate connector on their own with no other wires connected..  (Permanent live)
BUT...  I would never connect & re-energise without first double checking the above polarity assumptions with an approved voltage tester.
AND.. I would be concerned that you don't have some earth wires to be terminated as well?
Do you have any test equipment ?
Guinness
At a guess...
Guinness
Hi good morning thanks for your help much appreciated, it has the earth in the connector box and the roof yes, no test equipment no,I did try to put a pic up here but couldn't work out how to,thanks again  though.
