certificate training
the_mouse
Jul 15, 2008
83
is there anyone who offer training in filling out certificates, either one to one or remotely?
Filling in certs does seem to cause many people problems, myself included, especialy when changing a consumer unit.
thanks
mouse
p.s. im in North East Wales
The OSG and other publications that i have, all show perfect world scenarios. Some examples that give rise to confusion are; when changing a consumer unit an EIC needs to be issued, on the schedule of inspections does "routing of cables in prescribed zones" apply to the whole house or just the work you do, in this case the CCU change.
another example, i recently observed someone change a CCU and he replacement was a Volex dual RCD board, the rcd
The OSG and other publications that i have, all show perfect world scenarios. Some examples that give rise to confusion are; when changing a consumer unit an EIC needs to be issued, on the schedule of inspections does "routing of cables in prescribed zones" apply to the whole house or just the work you do, in this case the CCU change.another example, i recently observed someone change a CCU and he replacement was a Volex dual RCD board, the rcd
It can be a bit confusing on numbering of circuit nuetrals and CPCs, many makes of Consumer Units do not tie up right.
I always number the MCBS/RCBOs from main switch and keep Nuetrals and CPCs in order to match even if the numbering on there respective bars do not match up.
Numbers are numbers wherever they are. If there are no numbers on the bars do it in order. If there are numbers and you order them according to somethign other than the numbers then I would class as incorrect.
I always put as much information as i can in the "Extent of installation covered by this certificate" box
That way it saves confusion, and describes exactly what works you certify
is there anyone who offer training in filling out certificates, either one to one or remotely?Filling in certs does seem to cause many people problems, myself included, especialy when changing a consumer unit.
thanks
mouse
id say the 2391 is a good start.
Them certs look good mate. Where did you get them from if you dont mind me asking?
At the bottom of your last sheet. Your tester serial number needs to be entered but maybe you n/a'd it as its on public forum?
Cheers
Them certs look good mate. Where did you get them from if you dont mind me asking?At the bottom of your last sheet. Your tester serial number needs to be entered but maybe you n/a'd it as its on public forum?
Cheers
The certs are Tysoft easycert, the serial number was removed being on a public forum.
I'll start at page
position- owner,
surely something like proprietor would sound more professional.?
page
2
have you actually seen the overcurrent protective device? or do you have it in writing as to what it is? you have stated on a legal document that you know what it is as a fact.
U = does not equal 240v, never has.
double or reinforced insulation = N/A are you sure? at the very least what about the tails? or any pendants you may have (class II fittings remember)
fire barriers etc = N/A again this wouldnt be an N/A , imm htr with HR flex for example, at the least you would have to make it a limitation
page
3
why is the shower 5s disconnection?
just a few things to ponder,
not meant in a bad way, just food for thought.
HTH
Nominal voltages seem very nicely rounded off. Have you actually tested these?
In reply to the above, the position box on any certificate would relate to your trade position, electrician, qualified supervisor and so on. This would lend weight to the authorised signiture
well spotted Manator,
the certs I use actually require a second signature which would I suppose be for that purpose,
yes, a professional position would be I think the only acceptable thing for that box.
I'll start at page1
position- owner,
page
2
good point, the suppliers protective device was not checked because there was an isolation switch, would it be a good idea to note it as not verified in box 7 page 1 comments on existing installation
that was inserted automaticaly by the sofware shall see if can be altered
Again good point and duley noted
noted
page
3
thats my fault, this was an install which i observed and noted test results for cert filling practice, i originally thought the shower circuit was in 10mm t&e on a 40 A MCB, i since learned that it was actualy 6mm on a 32A MCB i just forgot to amend that column when i edited
HTH
Many thanks for looking apreciate your input
mouse
I was under the impression that it was declared values not actual in this case, but as always i stand to be corrected
single phase supplies U and Uo are 230, i did not think you were surposed to record measured values
