Lurch,
Why should you have to test nominal voltage, this can be by enquiry?
me in red.I note that you have put N/A in the box for double or reinforced insulation.Are the meter tails not double insulated?
You have also put N/A in the box marked SELV, then ticked the box for electrical separation. its not the same thing
What sort of electrical separation is present? a shaver socket at 230v could be.
You have ticked the box marked segregation of band I and band II circuits.
What band I circuits are present. some stuff not at 230, alarm/tv etc...
Finally you have used the term LIM in the box for IR between live conductors.
Where is the box for detailing the limitations, and when was BS7671 changed to allow limitations on an EIC? this I agree is a very strange one, but you can limit the extent of the installation you have worked on, ie, extent of work carried out box. Im a bit at odds with this myself, but, what do you do.?
The reason for the limitation is detailed in the notes on the schedule of test results page. Should there be a specific box for this?Finally you have used the term LIM in the box for IR between live conductors.Where is the box for detailing the limitations, and when was BS7671 changed to allow limitations on an EIC?
Not trying to be argumentative, just trying to learn, all examples of a filled in EIC are all complete installs from scratch, i dont have an issue with this, a CCU change is a different kettle of fish and i havent seen an example of one, this is why i enquired if there was such a thing as certificate training.If you look at the notes for the schedule of inspections on the model forms in BS7671, you will see reference to LIM. You will also see in brackets that it is only applicable to PIRs.When conducting a PIR, there is a box for recording any limitations that apply to the inspection and testing, in the OSG example (page 152), they list no dismanteling or lifting of floorboards, which are fairly common.
The normal practice when testing IR between line and neutral connected together and earth is to indicate on the schedule of tests which circuits are vulnerable as shown in the example in the OSG (page 147) or sometimes by actually listing the vulnerable equipment as in the OSG example on page 140.
Although this is an alteration, and not a new install, initial verification is still required.
so are you saying that if you yourself change a consumer unit you would remove all decrative lighting all fixed loads lift floorboards etc possibly damaging the items and decor??
If you read the bottom of the model form page 333 in BS7671, there is reference to schedules, which indicates they are in fact part of the EIC.
It states: "The attached schedules are part of this document and this certificate is only valid when they are attached to it."
have to disagree with you on this one as you have written they are part of the document not certificate however the EIC is invalid without them so i see where you are coming from
I would also draw your attention to the last paragraph on page 334 in BS7671, which states:
"This certificate is intended to be issued only for a new electrical installation or for new work associated with an addition to an existing installation. It should not have been issued for the inspection of an existing electrical installation. A "Periodic Inspection Report" should be issued for such an inspection."
You seem to be suggesting that this EIC could be some form of combined EIC/PIR.
as i posted this was suggested in the book a practical guide to inspection, testing and certification by Christopher Kitcher which makes sense to me, A CCU change does effect the whole installation and tests need to be carried out to ensure the circuits meet the current standards, but you cant be expected to rip up floorboards to ensure there are no hidden juntion boxes, trace circuits to ensure they are in safe zones etc...
In which case I would expect there to be a note of any limitations, and LIM to be used instead of N/A for instance in the box marked 'Routing of cables in prescribed zones'.
This is where my confusion starts, and maybe im not expalining very well, the actual testing i dont have a problem with its the inspections i have trouble with:Certificate training is IMHO a bit like asking if there is any training for fixing labels and warning signs, or writing invoices?If you understand what work you have done..
you will know what inspections & tests you have done..
The certificate is just a record of those tests & installation details no?
Guidance note 3 gives clear details of the sort of tests needed and what are acceptable results.
right penny starting to drop, in reality if i install it it would be a tick in the relevant box if i dont its N/AYou are only ever responsible for the work you do...That is why you have the description of works & extent of the instillation covered by this certificate box.
Why the issues with a CU change..
What about when you add a new socket onto a ring...
You cannot rip all the rest of the ring cable about to see where it runs???
It is YOUR work you are signing for!
so you fill in all the relevant boxes and readings relating to the work you have done.
