Change over switch
safedepth
Apr 5, 2008
463
South Hams, Devon
A customer wishes to supply the lighting in their hall from a PIR sensor but is concerned they will become fed up with the control system and may want to control via standard 2 way switching set up. I have suggested installing both control systems and a changeover switch mounted locally in the CU cupboard box. They could then alternate the method of control at their will. Could anyone suggest a source for such a changeover switch please?
Many thanks.
ProDave,
Would that be as the feed on the common and each load on L1 and L2 respectively, all neutrals joined together? Or am I missing something?
