Depends on the end result required. If it's just cables inside a cu then I just extend each conductor as necessary. If it's outside any enclosure and a slim joint is required (for looks or burying) then I stagger. If it's just going under a floor or in a loft I just cut it square.Just a quedtion to the crimping fans, do you stager your crimps or jus as you cut thr cable?
