bit late now, but when you moved in you should have 'lost' the prepayment meter, then called supplier saying you just moved in and there is no meter...
And how would you loose a meter?bit late now, but when you moved in you should have 'lost' the prepayment meter, then called supplier saying you just moved in and there is no meter...
so considerably MORE expensive to NOT have a prepayment meter
confusing or what?
Yes you can, and don't let anyone tell you otherwise! We are on prepay, have been for years, and we were with BG, however we got offered a good deal with UTILITA we gave them the details, and away it went. We got an email and letter telling us what date the changeover would take place and to run our credit down, they sent a meter monkey out and the meters got changed, we were with them for 2 years and got a better deal with OVO, so changed again, there's nobody can force you to keep their meter, if push comes to shove then do what I did years ago. I had a meter that I knew was reading wrong, charging me more than I was actually using, after several complaints and getting nowhere (BG) I rang them and told them if there wasn't someone here within 4 hours to replace it, then I'd remove it myself and throw it in the street, it's on my property, my rules! within the hour I had a meter monkey on the doorstep with a new meter.cant switch until prepayment meters have gone
