Hi all..
Doing a little favour for the people next door. They want a 32a supply to their shed and hot tub. I am busy splitting the tails with a henley block and have installed a separate CU to feed the shed.
Now, the existing tails exit the bottom of the meter, turn sharp right [installer obviously never cared about bend radius] and set off to the original CU. They have also covered the one tail with insulating tape [for reasons unknown] and each tape enters the metal cu through a separate hole, so clearly not the brightest..
Anyway, there is NO WAY that i am going to re-route these tails, [they need to go left instead of right] as pulling them round 180 degrees is likely to affect the security of the termination in the meter terminals..
I have pulled loads of fuses [after a visit from the seal fairy] but never meter seals.. Now i know you are all going to say i have to contact the supplier, BUT, these tails belong to the customer, so to my mind he/me/we can do what we like.
Here is one documents from ukpn that show that he/we/ own the tails and state that "electricians" can replace them..??
See item "8" on their picture.. Sorry the picture is so bad but for the tails from the meter to the CU it reads "Consumer unit tails; These cables connect your consumer unit to the meter. They can be connected and maintained by your electrician because they're part of the internal wiring"
What you all think??
Secondly, what you all use to seal the things back up again??
john..
john..
