Stormbringer
Hi All,
My house alarm external siren stop working and I went to purchase a new siren, this company didn't have a siren to suit as this box was fitted back in the late1980's and convinced me to buy a new box.
I came to fit it today, took the old one down fitted the new one and then came to wire it in.....
I took photos of the wiring so not to make an error.
The old box had two wires going to the after market strobe.
Then on the board the terminals had
Tamp 2 wires to micro switch
Bell 2 wires to the Siren
T - yellow
A - blue
B - black
C + empty
D + red
TAMP T A B C D BELL
the Texecom Box had and I wired as below
MSW Strb Ov Tmp Bell +12V
2 1 S D C B A
2 1 were pre-wired
S Green (for strobe)
D Red
C Yellow (tamper)
B Black (Bell)
A Blue (+12V)
When came to set and test the alarm I cannot set it, I just have the Tamper light showing on the control panel.
as you can tell there is no T on the new box where the yellow wire fitted so i had a guess at C but this doesn't work.
The system worked perfectly except for no external Siren so I'm thinking it must be this Yellow wire causing the problem.
There is a area on the board next to the terminals that could have more terminals fitted (maybe the next model) on the board it reads
Fault relay, Tamper Relay and Test with a T underneath so maybe my yellow wire should have fitted here?
I hope you can understand the above and can give me some advice on what to do next.
Thanks it advance to any posts.
T - yellow
A - blue
B - black
C + empty
D + red
TAMP T A B C D BELL
2 1 S D C B A
2 1 were pre-wired
D Red
C Yellow (tamper)
B Black (Bell)
A Blue (+12V)
