Lillpete
- Jan 18, 2009
- 214
- 0
I have just been to price up for putting in a new supply (new board fed with separate TT)
In the email he has from the manufacturers it says "It has been found that it sounds better with a higher rated circuit breaker, so use a 32A as standard. A type B will still trip with a system like this, so it still needs a type C curve. also use the largest cable you can fit, at least 6mm and preferably 10mm.
If you want the best sound quality then you should fit a separate mains earth rod. wire the incoming cable earth to the house earth at the consumer unit (to protect the cable) and the earth at the sockets for the HiFi to the rod - do not join the two earths together"
I can understand the idea of running in a clean earth as his amp has a bit of a buzz to it but I don't see why running larger cables would help reduce this??.
Not having wired a clean earth supply before am I right in thinking that you would connect the bonding and main (pme) earth to the ccu but install an earth rod and run a separate cpc to the earth of the cocket??
