MehI find it unacceptable to quote a members post in a modified form.
Complain to admin7 then to possibly get that changed. It is a regular thing on here, but as stated above your original post cannot be changed by anyone.I don't agree with having words put into my mouth, I find it unacceptable to quote a members post in a modified form.
There is no problem, you are trying and failing to make an issue when there is no issue. What you are succeeding in doing is side tracking the thread and making it about you. Someone quoted your post and modified it in theirs, who cares only you it seems. Get over it.First rule of management is resolve a problem not move it sideways.
What concerns me is that this seems to be acceptable behaviour by those that have responded on this subject, I just hope it does not turn around and become a litigation issue.
Litigation Jesus Christ whatever next.
Quite correct I do care as it was about one of my posts, resorting to the need for blasphemy to try and get a point across is unnecessary.
No you are missing the most important point, any casual observer will see the modified post and not know that they can see the original by clicking on the arrow beside the name, I certainly did not know that until the moderator mention it, therefore the casual observer will attribute the modified post to the original poster, I did say if everyone stoped posting on this subject I will also, you seem determined to keep this going.
But you want people to carry on posting to continue the inane point you are trying and failing to make. You like to argue trivial points because you believe you are superior, gives you a sense of importance and this may work in your life outside of the forum but it doesn't work on here.I did say if everyone stoped posting on this subject I will also, you seem determined to keep this going.
So in a nutshell……Codebreakers is ok if you’re starting out……as long as you don’t edit the original post……
No its not OK.
The BPG No 4 issue 5 is more accurate
