Today's job was to make good boiler wiring.
There are 2 roomstats with 2 diverter valves for upstairs and downstairs zones and its a combi.
Its a 2 year old system which has never worked correctly. When calling for heat on downstairs stat both valves open so whole house is heated. The same applies to the upstairs stat!
Wiring is a total mess but basically the permanent live is connected to the brown wires of the valves hence the valves are open all the time so when any stat calls for heat the whole house gets it.
Anyway got it sorted and now working ok but still not happy.
As its a combi, the boiler has a permanent live so in effect the orange wires of the valves become redundant or am I missing a trick?
Normally with one roomstat I would remove the stat link in the boiler and connect the stat across it, but this cannot be done with 2 roomstats. I've left the link in place and wired perm. live --stat---brown of valve.
Anyone come across this before?
How did you overcome the problem?
