- Dec 25, 2011
- 5,468
- 78
Vailent combi boiler problem in an empty property being refurbed - if I leave the wireless stat up i.e. so that the place is excessively warm all's good. However set the stat low just to "keep the frost off" then after a couple of days I get an F22 pressure fault come up. I have to refill via the two valves on the bottom of the boiler. Pressure gauge climbs into the red after a while and I have to lower it by draining off from a rad. It settles down and all works until I again lower the stat setting. Any suggestions?
As I say leave the temperature up high and no problems. Just wondering if there's maybe a leaky joint under the suspended ground floor - joint cools and leaks but is fine when hot.
I know NOTHING really about combis.
Cheers
Cheers
