hole top or bottom does not matter when its comes to IP rating's like the IPX5 and aboveDon't drill the top as water could get in , drill the bottom or bend the banjo up for a pin & nut .
Put the banjo on the inside , some people do anyway , theres usually a way .
as for two lock nuts plus the box wall and the banjo, I normally run out of thread
I have for some time now been putting the banjo on the inside of metal boxes as they can be seen better and keep cleaner
yes you are right I was just saying you could use the MK thingy it has a thread ,"O" ring and an earth cable , so pretty water tight for the plastic box, it just looks better on the wall than a 4X4 glav box and socket below/aboveAs others have already said, never tighten the gland directly onto plastic when using the swa as the cpc. Always sandwich the banjo between the gland and a locknut first. Many newer items such as Pirana nuts are also availible but these can not always be used if the thread on the case is deep. Sometimes its easier to gland off into a steel box first.
