jamespurcell1983
- Joined
- Jan 26, 2010
- Messages
- 3
- Reaction score
- 0
Hi all,
I just moved into my first flat. It's pretty run down. The water heating is provided by a Newlec Economy 7 system.
The control panel has a rotating time dial which I have set to the right time. It also has a 'Boost' knob.
My problem is that when I just leave the water heating to come on on a timer, nothing happens. I know that it's supposed to come on between 23:00 and 7:00 but it doesn't even do that. The only way I'm able to get hot water is by using the 'Boost' button.
I have taken off the front panel and can't find any obvious reset button. Any idea what might be causing my problem?!
Thanks in advance for any help you're able to offer!
James
James
