spinlondon
Distinguished Member
- Apr 18, 2009
- 1,388
- 0
Don't forget some heat shrink, and perhaps a butane soldering iron with a heat gun attachment. Portasol do one.
NIC dont make the regs. as long as work is to 7671, he cannot fail it, even if its against 'NIC regs'According to NICEIC chock blocks in a consumer unit is not allowed you need to crimp them through CJS
use them and its a guaranteed failive got a hand crusher type without the ratchet, would that get me out of trouble you recon just for my assessment?just like this with this connector
i mean the crimp tool, the blue crimp there is the right type (but you may need the red or yellow depending on size of cable)what connectors do i use then?
PLEASE PLEASE PLEASE PLEASE PLEASEthis is what ive used at moment
people mentioned a choc bloc but it wont fit hmm
Also have a read of section 526 Electrical connectionsAny of the above mentioned...Wagos, crimps, connector blocks..
(providing they are of a suitable current rating for the cables they are terminating!)
And they will be inside an enclosure that needs a tool to open it up so all perfectly safe and in compliance with all relevant regs IMHO!
Any reference in any NICEIC documentation to back up this unsubstantiated allegation??? ?:|According to NICEIC chock blocks in a consumer unit is not allowed you need to crimp them through CJS
I have worked for two NIC companies whos area asessor (possibly the same one) will pull them up (dont know action taken) about un fixed connector block.As I have said many many times before...It normally electricians hearing half a story off another mate who is a plumber.. who told him about something an electrician told him!!!
which was probably wrong anyway..
But then it becomes
NIC said this and its LAW!!!!!!!!!!!!!
:Oheadbang
That's what I mean by a choc block. Have I got the terminology wrong here? If this isn't a choc block can someone learn me what one is please?this is what ive used at moment
thats a choc block.That's what I mean by a choc block. Have I got the terminology wrong here? If this isn't a choc block can someone learn me what one is please?
If the circuit is RCD protected and the light unit is class II, then refer to the ESCs BPG on lights with no cpc. You should fit a sticker (*) to the CU and note it on your cert or if you've got the time pull a cpc across the loft from another light on the same circuit.i know what you mean. The amount of people who think on a rewire the sockets have to be half way up the wall and low light switches for disabled peopleSpecial location can you help me with this please:
the bathroom light at the consumer unit job hasnt got an earthing point and hasnt even got the cpc going to it, i havent looked in loft to see if its there. The light is all plastic with a glass dome and assumed it is class2 but it doesnt have any markings. What should i do? put a comment on the certificate under comments on existing installation? something like no earth wire in bathroom light?
want everything spot on for this assessor
thanks
only time is required, but ramp testing can be useful for other testing / fault finding purposesi the rcd test current tested? usually only time isnt it? my test meter has both
Are the label people not sponsers of the forum.If the circuit is RCD protected and the light unit is class II, then refer to the ESCs BPG on lights with no cpc. You should fit a sticker (*) to the CU and note it on your cert or if you've got the time pull a cpc across the loft from another light on the same circuit.* something like this, but most wholesalers sell these:
http://cgi.ebay.co.uk/100-x-No-Provision-Earth-Label-Electrical-Label-/250578486960?pt=LH_DefaultDomain_3&hash=item3a57a446b0
