Consumer unit change and testing.
If you are connecting circuits into a new CU someone elses bodge becomes your bodge:O
It shouldn't do if you follow the guidelines:
5.3. However, circuits that are defective or noncompliant
with the requirements of BS 7671 in a
way that would result in real and immediate danger
must not be connected to the consumer unit.
ESC:innocent
This is why ALL paperwork should be 100% correct when changing a CU.
However, im sure "someone" will find fault with the above.
This is why ALL paperwork should be 100% correct when changing a CU.However, im sure "someone" will find fault with the above.
may be you will get a few more stars *** in you rep box mate :D :D:)
on a serious note i agree, paperwork should be accurate for cu change and for all work really
Get yourself a Kewtech plug tester and akewtech light tester set
Plug tester
Well guys, thanks very much for your input, two things are clear1) There are a number of ways to test after a board change.
2) There is a massive hole in my electrical education and think its fair to say im at the bottom of a large steep leaning curve.
best regards
mouse
1) wrt one of your questions, I do R1+R2 on lights wherever I can, but no longer take down fancy fittings ('cos I've been caught out a couple of times having difficulty putting them back 'cos of poor fixings etc) so I do R2 only from the met to the light unit casing. I will often put both R1+R2 and R2 results on the cert.
As you say though, many ways to skin a cat
2) In the same way that any physical activity is made easier by the use of the right 'gear' and technique, so climbing that metaphorical 'learning curve' is made much easier by having an open and enquiring mind receptive to new ideas. Keep watching, asking and learning. Well done.
---------- AUTO MERGE Post added at 14:24 ---------- Previous post was at 14:22 ----------
Get yourself a Kewtech plug tester and akewtech light tester setPlug tester
To consider some basic facts and probabilites...
If you picked a random sample of 1000 domestic properties and did a full PIR on them all...
I would guess that 80% of all circuits on all installations would test out good and could go straight onto a new CU without a problem.
I'd like to be working in the houses you are... find loads of faults on consumer units we do... and I'm by no means over the top with fault finding... all these DIYers messing up ring mains... in about 80% of cases there is always a fault with a ring main I find... mainly with end to end continuities of conductors.
[quote name='Andy
I'd like to be working in the houses you are... find loads of faults on consumer units we do... and I'm by no means over the top with fault finding... all these DIYers messing up ring mains... in about 80% of cases there is always a fault with a ring main I find... mainly with end to end continuities of conductors.In my opinion of british law and ambulance chasing lawyers If you were the last man on it it's easier to blame you than try and find out who actually bodged it therefore you're going to fully cop for it... allways better to cover your back.
I'll go with that, as much as it may not be right, its how it usually works. :(
Thanks for those links Steve, do the lightmates work with the Megger MFT1553?
B
Thanks KME -any 4mm test leads/tester work with R2 socket/lightmates
I use Megger 1552 - cool kit - just ask Megger Mark
