yes, im going to try this- will post here with results.a UPS with AVR (auto voltage regulation)bob
so you would rather try to hide the problem with a UPS rather than get the problem fixed?I'm thinking along the same lines as Bob,,Dirty supply, low supply voltage, harmonics
Could be due to a faulty joint in the supply cable or a nearby factory??
I meant in the reasons for the buzzing, not that a UPS is the cure...so you would rather try to hide the problem with a UPS rather than get the problem fixed?
well thats OK then! hate to think were now working at ways of hiding faults rather than correct them! (thats what the DIY forums are for!)I meant in the reasons for the buzzing, not that a UPS is the cure...
