tom1
Distinguished Member
- Aug 7, 2009
- 2,331
- 0
got a couple of questons
1. induction hob flex cable, 7.4kw hob, ask for 90 degree flex. shoped around a bit and i can only get this in 2.5 mm, i wanted to use 4mm but i can only find this up to 85 degree, any idears
2. got a microwave 3.4kw, says can be fitted with plug, tad over 13 amps but i doubt it will use 3.4 kw. can also be hard wired in so i was planning on putting it on same circuit as the 3.6kw oven. all on a 20 amp mcb. would i be best of fuseing down the micro?
thanks for advice
thanks for advice
