Just finished off the wiring for a boiler and when testing the RCD I found that whilst all the readings are within limits, the switch does not drop; you have to pull the switch down before you can reset it...
Now I know that Crabtree (Starbreaker) RCD's are not mean't to operate like this (unlike some older Square D)...
So is this a fail or just a comment on the EIC!!
