ian932
It is, but the scenario here is that there is no cpc on the lighting circuitIs this why we put the earth on the back box????
You used to be able to get P.V.C screws,dont know if you still can,not seen any for a while.Would a light switch need to have hidden screws as these would be extraneous conductive parts if fitted to a metal back box ??
Blimey Apache, you don't miss a trick:^OOh you chaps are useless. It was Ext 15 you gave the tip to*sigh*
I've had a right good belt off one when some clown thought it would be a good idea to use the cpc as the third wire for a 2-way circuit and thought it was an even better idea to not sleeve the cpc which ended up touching the box making screws live. Even better the house was sold to landlord by a sparky who had rewired the whole house.As far as I'm aware no one has ever died from touching the screws on a Class 2 light switch..(with a metal backbox)
