- Nov 28, 2009
- 14,720
- 891
Here's another advantage os loop in switch:
If you want to add an extra light and change a 1G switch to a 2G switch for the extra light, having the neutral at the switch often makes that easier.
Most common example is a switch by the back door on an outside wall. Easy peasy to turn that into a 2G switch with the extra switch feeding an outside light if wiring is loop at switch. Much much harder if loop at light fitting.
I always use 25mm back boxes for loop at switch.
