how?So 23 years ago when you were sparking people probably had pendants or a centre lights nowadays and on some jobs that I have done they have downligts in every room now if you don't put your neutral in your switches or use the spider method you have four cables at the first downlight in most rooms this is really not a good way to wire this system. Loop in switches is a better way as far as i'm concearned.
L&N and a pair of switch wires, or, if you take the L&N to the switch then you simply have switched L & Neutral at the light, much easier.
