Hi, I hope someone can give me some advice. I have two Dimplex Duo Heat 500i heaters. Both have seperate electrical feeds, for night and day storage. On the instructions it says I can set the night background heater temp by pressing the + button until 10 bars are full then continue to hold for a further 7 seconds until the led's flash. On my heaters, I press and hold as instructed but the heater doesn't flick over to the background heater temp setting.
I have had the thing apart and tested electricity is being delivered to all components so I know they're powered.
Reading some of the threads on here, I either have to reset the device or I can only set the background temp when I'm in an off peak time (between 12am and 7am)
Would someone know what option I should go for and if it's the reset option, where I am likely to find the reset button.
Thanks in advance for any advice.
Boxy
Boxy
