I'm new to the forum and look forward to any hints of tips people can give me on the subject of my Dimplex night storage heaters.
Recently I removed the front panel and bricks in order to install a new wood flooring. I put the heater back together as I found it however the screw in the bottom left hand corner will now not fit so the heater is slightly open at the bottom.
I have been testing the heater on different settings however I always put the output to 0 as I am usually at home later on in the day when I believe I can increase the output to release heat.
However the heater always seems very hot in the morning then just loses heat throughout the day and when I turn the output up it seems to make no difference.
Could it be the little gap at the bottom is causing this problem?
Or could it be the output flap is wedged open so it is just releasing heat constantly?
This is a 2.5kw heater and it is using around 1.5-2kw of energy per evening turned up to 5-6 input. It is hard to say exactly how much is being used as I also have my gledhill water heater on at night on the economy 7 electricity.
Should I take it apart again and if so what should I be looking for?
Any help much appreciated.
