Regarding the noise of AC coupled inverter. I have decided that it will be better to site the battery and inverter in our porch. I can run 6mm SWA and the comms lead outside and get the electrician to drill a hole through the wall next to the CU.
If the shipping delays hitting the states are anything to go by, it could be laterSolis still telling ITS August for the inverter apparently. ITS tell me they think it is more likely September..
The permission from the DNO only lasts for a year, after which I'll need to reapply.If the shipping delays hitting the states are anything to go by, it could be later![]()
When you say porch is it a brick built. Make sure it's not a uPVC porch as they get rather hot and your equipments life can be reduced. I had my first system placed in the loft. I would never advise a loft unless you make sure the equipment is well ventilated specially in summer months.Regarding the noise of AC coupled inverter. I have decided that it will be better to site the battery and inverter in our porch. I can run 6mm SWA and the comms lead outside and get the electrician to drill a hole through the wall next to the CU.
There is a shortage of equipment I cannot get a growatt sph5000 until December.Solis still telling ITS August for the inverter apparently. ITS tell me they think it is more likely September..
Ive seen somewhere with SPH7000 in stock, I'm trying to get SPH6000 though. Looks like I may have to import myself or use an alternative inverter.There is a shortage of equipment I cannot get a growatt sph5000 until December.
Thanks Gian.When you say porch is it a brick built. Make sure it's not a uPVC porch as they get rather hot and your equipments life can be reduced. I had my first system placed in the loft. I would never advise a loft unless you make sure the equipment is well ventilated specially in summer months.
Register today and take advantage of membership benefits.
