Berserkerboy
So there's a nut on the back of the inverter on the cooling fins with the grounding symbol and the battery also has a small nut with the grounding symbol.
Grounding I believe is an American term for bonding. Earthing and bonding being one of the most complicated subjects you can encounter .Sorry berserkerboy. I'm not allowed to answer this one. Binky said Ive got to leave the electrical side to the expert's
Though I do know grounding and earthing are not the same (technically)
Terminate SWA to an adaptable box, then run 6mm from there to inverter. Ideally use hituf or ho7rn flex, coz it's round and can just about be jammed through the patheticly small glandHmm. Bit of an issue: Solis specify 6mm cable for the inverter AC connection. So I bought 14m of SWA. It has OD of 15mm. However, the gland that the wire needs to go through is only 12mm..
I can't go to a larger gland as the hole in the metal bracket that houses the gland is only 20mm diameter.
It's possible to clamp the inner sheath of the SWA as it is 11mm diameter.
Any suggestions?
It's sounds like it's designed for grommets only. Any cables leaving that enclosure need clipping to prevent any tugging on the connections.I bought one of these as an isolator.
I need to run swa to it and then 11mm diameter cable to the load. (inverter).
Described as having 20mm and 25mm knockouts I bought 20mm swa gland kit and 20mm nylon glands.
However, these do not work as the housing has reinforcing inside, meaning that the glands do not protrude enough inside to get the nut on.
Anyone had this kind of issue before?View attachment 15062
https://www.toolstation.com/imo-stag-lever-type-isolator/p93673
You were able to use standard glands?Don't know about those isolators. You could nip to a electrical supplier and ask if they have gland nuts to fit the box. Or try these
https://www.obo.global/products/ind...ds/cable-gland-long-metric-thread-black.html#
I used the kraus and naimer isolator. Plenty of room in them and no reinforcement
Yes m8You were able to use standard glands?
Best thing you could do with it, for it looks like rose foodI'll have to take it back to Toolstation.
