Berserkerboy
Ah, thanks again. OK. I'll order a double-pole rotary isolator today.
I always send a email to Solis. They do reply though upto 48 hour later. Once the conversation has started they reply pretty much instantlySolis customer service line is just playing me Rick Astley and Abba etc .
I've emailed them as well. Hopefully have an answer at some stage.
Obviously, had to turn it all off. Very disappointing!!
Excellent. My thoughts are that something is very off with the inverter regardless of other settings. Export limitation at 0w and switched on should overide exporting 3kw from the battery.I always send a email to Solis. They do reply though upto 48 hour later. Once the conversation has started they reply pretty much instantly
Thought that option was only for a depleted battery? The inverter is seeing the battery and emptying it back to the grid.Did you click the wake battery option?
Charging from grid and discharge to grid are turned off. Havent seen a self charge option but assume that if the others are turned off then self charge is the default?Have you turned on the self charge? Or have you set it to charge from grid at certain times?
