Good job that was done by proffesional's. Amatures might have made a mess of it.
I think it’s the new version of the angled bit of non-weatherproof chipboard to stop the service having two 90° bends in it due to the utterly ***** design of the boxesThat’s a mess, never seen line taps used in the meter cabinet before, and why is the dno cut out not secured to the backboard.
When I was metering especially smart metering you need a lot of space with the Comms unit additional aerial if needed. I had to abort so many jobs because of cram packed equipment that should not have been there.I've read that some DNOs allow the upper right quarter to be used, but I doubt that extends to the use of line taps or tails and outgoing cables blocking most of the other 3/4. NIE specifically prohibit the installation of any equipment, although I've never known them to object to neat, unobtrusive installations.
I went looking for information after posting and it seems UKPN had been okay with that quarter being used, but the page now seems to have been removed from their website.When I was metering especially smart metering you need a lot of space with the Comms unit additional aerial if needed. I had to abort so many jobs because of cram packed equipment that should not have been there.
Yep DP isolatorI used to have a drawing from, I think UK PN that showed a quarter of the back board was for customers equipment
