I'd appreciate some advice please...
I'm in the process of starting an Electrical Contracting business from scratch.
I've worked in this industry as a Project Manager for 15+ years, and most of the last 5 years in senior management and business development so I'm confident about getting everything up & running.... but I am not an electrician.
I started my career manufacturing & wiring control panels and I've done a lot of site installation on industrial automation sites.
I have done a BTEC ONC in Electrical & Electronic Engineering, I've done my 16th & 18th Edition and Part P and currently studying my 2391-52 for Inspection & Testing.
... So I'd like to think I've got a fair bit of general knowledge and enough to cherry pick some work while I'm getting things setup.
I have very little domestic experience myself, but once up & running I will be employing people that do have that experience, but I suspect that domestic work is the easiest market to get started in.
Ultimately I'm looking to register the business as an Approved Contrator with NICEIC (as this is still a requirement for many Clients I've worked with and NAPIT isn't accepted).
I believe I can now qualify to register as a Domestic Installer as I have everything in place and I've done a couple of small jobs that will hopefully pass my assessment.
I wouldn't be able to qualify under the Approved Contractor scheme yet.
I'm trying to minimise my start-up costs by not employing anyone until after registration hence doing it myself.
Am I right in thinking that non-residential works can still be carried out without being an Approved Contractor if the building owner accepts that?
In other words, should I go ahead with my Domestic installer registration so I can start doing notifiable work and then look at doing some Commercial work and using that to upgrade to Approved Contractor later? It sounds like from application it will still be a few months before NICEIC will be able to come and do an assessment.
Can anyone provide any advice as to why I should or shouldn't go for Domestic Installer now and then upgrade fo Approved Contractor at end of year renewal?
Thanks in advance.
Thanks in advance.
