Door Entry buzzing
binky
retired and loving it!
May 7, 2008
15,050
2,000
Sunny Plymouth
Had a look at a door entry system this morning, Northern Bell, so a bit of a cheapo unit and roughly 15 years old to boot! Now I changed the power supply / control box about 10 months ago, which got it working, but the residents are moaning that it's not working properly again / possibly some of the flats have not worked longer than that. I am a little intrigued as to what is making it buzz constantly, it's so basic, that all you have is the doorbells, a small control box/ power supply and the handsets in each flat. Is it possiby a faulty handset that is causing the buzzing?
What's buzzing?  The door release unit, the power unit or the audio on the handsets?
Presumably it all works on low voltage DC.(?)    I would be looking at rectifiers and smoothing capacitors in the supply.
