door intercom
Andy™
©Resident Geordie™
Jan 1, 2009
30,696
1,403
S. Tyneside
i need a door intercom with 1 handset but connected to 2 door controls. any ideas?
was thinking 2x door intercom kits, with outside wired in parallel, but youll probably get audio through both
Could try these Andy -
Videx
I can't post a link to the website but it is videx-security.com
with the www on the front of course !
Been away and just seen this. I also try to use 'Entryphone' where i can. Costs a bit more but worth it. They do a kit that switches the speech and door control to which ever outdoor station is used. Its a small circuit board that fits in the outdoor unit. I try to sell the customer the coded entry as an extra ; \
---------- Post Auto-Merged at 18:31 ---------- Previous post was made at 18:25 ----------
This is the only link i can find, last door switcher i fitted was a couple of years ago and was as simple as i mentioned above. Give them a call as they are very helpful
Entryphone | Door Entry Systems | 98DCRU - Door capture relay unit
I've done a few Fermax . Usual made in Italy stuff but one fitted at the printers has lasted about ten years . Its well used all day long and recently the four code buttons packed up so I changed the code to four other buttons and working fine again .
Very helpfull with queries on the phone .
yep, most entry phones only use the code for the phone ring,
the audio is available on all handsets,
even in a block of flats, if someone buzzes you and you pick up, someone else can pick up and hear your conversation.
with the cheapo units that is obviously,,,
wireless please :)
house has just been decorated and they had some lovely laminate put down, no access from below either. :|
They used to have a wireless video intercom but the rocket scientists at the NHS insisted on a wired audio one, now they need a video one as the client keeps letting jehovas witnesses in by mistake !
:animal:
I looked at videx, couldn't see what I was looking for!? Do they really exist?
Its a nice victorian house, just been redecorated with tiled and laminate flooring. there also is a basement flat below.
The power supply for the defunct ( hey have the four legged variety) alarm system is by the front door, bonus.
Thinking about it maybe a wireless camera linked to the telly or iphone so she can check theres no one with a copy of Watchtower at the door? ( could be worse I 'spose)
Any other Ideas?
Running cables will be a bit of a headache and will take a lot of hot glue!
