pewter
Conspiracy Theorist™
I am looking for recommendations for some drive over sealed unit LED lights to go in a 100-110mm hole that has been made in block paving. ( i can make the hole slightly bigger if i really have to)
more options the better please.
The story is i have a great customer, big property and not on a budget. They had there drive block paved and the dumb builder/block paver/ driveway technician or whatever he calls himself ruined it by buying these http://www.tlc-direct.co.uk/Products/TLW35GU.html (a good reason why only sparks should be allowed to buy sparky stuff). There is around 25 of the drive over lights.
The rubbish TLC ones after a few years now have rounded off alan key heads and moisture inside due to top bezel & bad water levels below the drive when the it rains (areas suffer run off from a golf course and surrounding land)
I have found these by Aurora
http://gb.auroralighting.com/Products/Outdoor-Luminaires/Outdoor-Recessed-Ground-Lighting/Driveover-Lights/240V-Stainless-Steel-IP67-Fixed-Round-LED-Driveove.aspx
I am thinking sealed unit LED will be best option as no maintenance changing lamps and lass chance of moisture penetration.
any advice, ideas, sarcasm and bad jokes will be gladly received.
