You're probably talking about a days work to carry out an EICR (similar to a cars MOT), if there are problems then they would be at extra cost. As for cost then I'd guess at £200 at least for the test.ok thanks fro the help guys i did stop and think on shorting the wires and stoped there its only cosmetic yes the wires would have looked better shorter and neater but the ways out way the means so will leave them alone is the tidying better ? it was only a few wires(to an out side connector used for a pond supply) that are unused and a low volt tranforemer i have removed
as can been seen the new bonding wire now looped on the left of the box need to be connected to earth to contemplate the bonding the question i wanted to ask from the start is would it be better to connect this to the top board or the lower board if you look at the wire coming from the top board you can see a small green earth cable poss 4mm to the earth and the newer board connected by meb 13 years ago poss 6mm earth cable i would assume its better to connect to the lower box as the Resistance with the bigger cable is going to be less
again thanks angel for all help
can i ask how much would/should you pay to have the system tested and part p cert given if no problems found ?
For a Part P certificate,,,, a registered company can only certify their own work,,, no-one elses!
The only people who can certify other peoples work are the local building controllers (council) and you have to pay for that
