Cheers for the replies guys, every little helps! but now I have more queries!
I have little or no electrical background really, but I'd like to know how to work out things like fuse
/breaker amp sizes. for instance:
A fuse between the battery and the regulator (it's a regulator and controller in answer to your question M107), the amp size of the fuse/breaker would be worked out by the total sum of amps drawn from all appliances if you had the full load going, and from there you could also work out necessary cable thickness, knowing the amp load... am i right
here?? and same goes for the cables and fuses/breakers from the regulator/controller to the inverter or 12v fuse box?
Say if I we're to calculate that, on my 12v system, when all appliances are on, they're drawing 30amps, I'd want a 30/35 amp fuse from regulator to fuse box connected with 10mm2 cable (thats just what the graph
tells me for a 34 amp load). Is this in the ballpark??
Now, the relay to select between solar charge and mains charge, is this a manual switch, like a line selector?
From what i understand about diodes they block the flow of current in a certain direction. The issue is that the regulator is also a controller, so i need the batteries to run back to it to then go out to 12v fuse box and inverter. So could i install the diode between the solar panels and the regulator to achieve the same goal? i think i read somewhere that diodes provoke voltage drop... is this correct?
Lastly, between the two 150w 12v solar panels in parallel and the regulator, I've been told by one electrician to use 6mm2 cable
and by another to use 10mm2 with a 20Amp fuse/breaker, what method are they using to
work this out? I'd say that 150w divided by 12v would be 12.5amps, times it by 2 to get 25amps, meaning I'd use 6mm2 cable with a 25 amps fuse into the 30Amp regulator/controller.
Lastly lastly, i have no idea what amp size breaker/fuse to use from starter battery to leisure battery, as there are no appliances involved, how do you know the amp draw from one to the other?
I know there are a lot of questions going on here, and whoever takes the time out to hep is an absolute saint!
Thanks again,
Ash.
