Evening all , this is the scenario...
DB with a key switch bushed to it, and on another wall in the room a 1 way switch
4 lights in the room , the first light is Combined emergency luminaire , 2nd a standard fitting , 3rd a standard fitting and 4th a Combined emergency luminaire..
my wiring as follows..
3core from DB to first lighting point... Brown Permanent Live , Grey Sleeved Blue Neutral and Black Sleeved brown through the DB to L1 on the Key switch, link the MCB to Common on the Key switch..
Switch wire from the first lighting point down to the 1 way switch
3 core from the first lighting point to the 2nd lighting point and another 3 core to the 3rd lighting point ( emergency live connector blocked through until the 4th fitting)
my reasons for the 3 core is so that you can either kill all the lights with the key switch by putting the emergency live in with the permanent live or keeping the emergency seperate and only killing the emergency lights..
anyway im told this is wrong and you only ever kill all lights...
any thoughts ??
any thoughts ??
